Shops make a number of fundamental decisions while determining how best
to machine a new job. In the case of repeat work, progressive shops
eventually identify new strategies or equipment to make the setup and
machining of those parts more efficient and less time-consuming.
The adoption of atypical workholding devices by Five-Axis Industries
offers a case in point. A particularly large part that was a hassle to
fixture drove the Seattle-area shop to find a more effective means for
securing the part during machining. Although the conventional
tooling-plate method it had originally devised proved adequate in terms
of generating good parts, a total of 7 days was required to create a
fixture, set up the job and machine a new part.
Now, the
shop uses a magnetic workholding system in which multiple
permanent-magnet blocks are located at specific points under the large
steel part. Not only did this new workholding method reduce the part
production time from 7 to 2 days, but it also was versatile enough to
secure other ferrous parts of varying sizes on different machines with
comparable results.
Modular Magnets Secure A Marine Component
Erick Ellstrom is vice president of the shop that serves the aerospace
and marine industries, among others. The shop is part of Ellstrom
Manufacturing, which sponsors an unlimited hydroplane boat-racing team.
Mr. Ellstrom is both crew chief and team manager. Five-Axis Industries
machines various boat and turbine-engine components for this team and
other hydroplane racing teams and engine builders.
Not surprisingly, the aforementioned difficult-to-fixture part is
used in a marine application. It begins as a rectangular blank of 4340
steel that weighs 2,200 pounds (it weighs 1,300 pounds after
machining). The shop has been successfully machining this part for
years, but Mr. Ellstrom says it never developed what he considered an
effective way to secure it for the machining operations required on
both part faces. Mr. Ellstrom admits that the part is not particularly
difficult to machine, although it is big and heavy and has a taper on
one face that must be accurate to a tolerance of 0.002 inch along the
part’s entire 80-inch length.
Originally the shop built
a base fixture (a time-consuming process) and then bolted the workpiece
to the fixture through tooling tabs that eventually were machined off
of the part. Setup time using this fixture was lengthy, and a second,
long setup process was necessary after flipping the workpiece to access
the other face. In addition, because the workpiece was secured only at
points around its perimeter, the center section was “live.” That is,
harmonics during machining had to be minded so as not to adversely
affect surface finish and machining accuracy.
The shop
considered using vacuum workholding chucks, but those devices would
have required individual fixture plates for each part, too.
Electro-permanent workholding chucks were another option, but the
marine part would have needed a huge chuck and electrical supply at the
machine to operate the chuck. (Electro-permanent chucks require an
electric jolt from a control box to “turn on” the magnet. The
electrical connection can be removed from the chuck after this step and
the magnetic holding force will continue.)
The shop found a solution in the modular, permanent-magnet workholding blocks available from Earth-Chain USA
(Indianapolis, Indiana). The compact workholding blocks can be clamped
on a machine’s table wherever they are needed. The number of blocks
required depends on the size of the workpiece. Within the blocks are
north and south poles across which magnetic energy (flux) flows. When a
ferrous workpiece is located between magnetic poles, the flux enters
the part and induces a polarity in the part that opposes the magnet.
This causes an attraction between the part and magnet, and that
attraction provides the holding force (see drawing on page 87).
Unlike
electro-permanent chucks that require electricity to switch the chuck
into the “on” position, operators positively engage the magnets on
these blocks by using a wrench to turn an on/off switch. The magnetic
holding power continues until the switch is turned to the off position.
During setup of the large marine part, Five-Axis Industries first
positions a number of workholding blocks in a specific array on a VMC’s
worktable. Each block is topped with replaceable soft jaws. The VMC
then decks the top of each block so all are flat in relation to each
other. After that, the workpiece is loaded onto the blocks using a
crane and permanent-magnet lifting device. The lifting device works
similarly to the magnetic blocks and has a lever to switch holding
power on and off. Once the workpiece is installed on top of the blocks,
an operator turns the power switches on the blocks to magnetically
secure the workpiece to the top of the blocks.
Prior to
loading the steel blank into the machine, the shop first hones both
faces of the workpiece, which is done to help ensure that the precise
0.002-inch taper will be produced. Next, the top is rough-milled and
then finish-milled using an Ingersoll face mill. The part is then
flipped to allow drilling, reaming and finish-milling of its second
face.
Expanded Role
Five-Axis Industries has a number of the magnetic workholding blocks,
and it uses them on various machines to secure workpieces that have
different sizes. Mr. Ellstrom says the blocks offer setup flexibility
because they can be positioned as needed on a machine’s table to fit
within the profile of many workpieces. The shop also uses the blocks
not only to reduce setup time on ram EDM equipment, but also to
eliminate the need for dedicated fixtures. The blocks are effective in
holding such individual small parts because their poles are closely
located together and do not require a significant amount of surface
area to obtain the requisite holding power. (Maximum holding force for
the largest of these blocks is 4,620 pounds.)
