CNC Turning Center Features Quick-Change Spindle
The Hardinge Talent 51 MSY CNC turning center features the company’s quick-change collet-ready spindle designed for improved part accuracy and surface finish capabilities compared to conventional spindles.
The Hardinge Talent 51 MSY CNC turning center features the company’s quick-change collet-ready spindle designed for improved part accuracy and surface finish capabilities compared to conventional spindles. The machine is equipped with live tooling, a subspindle and a Y axis to enable part-complete operations. The 25-hp main spindle provides 5,000 rpm. The turning center has a 2" bar capacity, a turning diameter of 12.2", and a maximum turning length of 24.9".
The 12-station turret uses a ¾" square shank and a 1¼" round shank tooling with a 6,000 rpm maximum live tooling speed. The turret also provides a half-station index for up to 24 tools. Additionally, the machine offers a FANUC 0i-TF control with standard control features.
Starrett's Multisensor Vision System Provides Large Field of View
IMTS 2022: The AVR-FOV 0.14X multisensor vision system is designed to provide accurate, efficient measurements fora wide range of parts.
Swiss-Type Lathe Runs 2-Inch Parts Complete
This Swiss-type multitasking machine does all the crosswork and endwork milling, drilling and tapping complete, and even engraving and deburring, on one machine.
Horn Supermini Set Offers Greater Holding Force
The Supermini toolholder system offers clamping carried out via a clamping wedge on the face.
