Cutting Tool for Grooving, Threading of Small Parts
Tungaloy Corp. introduces the TetraMini-Cut, designed to provide high-precision and quality in grooving and threading of small parts.
Edited by
Tungaloy Corp. introduces the TetraMini-Cut, designed to provide high-precision and quality in grooving and threading of small parts. Its ground insert, with four corners, is well-suited for high-precision and high-quality machining of small parts. The insert pocket protects unused corners from chip damage during machining, enabling the use of every corner of each insert, the company says. A clamping system improves rigidity and repeatability. It is also capable of undercutting and finishing a flange wall, while simultaneously grooving on the shaft along the flange wall. The insert screw can be tightened either from the front or the back of the toolholder, which is designed to simplify the operation when mounted in a Swiss lathe.
Grooving inserts with widths ranging from 0.013" to 0.118" (0.33 to 3.00 mm) are available in SH725, a versatile PVD coating. Threading inserts with pitches ranging from 0.031" to 0.118" (0.8 to 3.0 mm) are available in AH725, the company’s PVD grade for a variety of materials including steel, stainless steel, cast iron and heat-resistant alloys.
5 High-Volume Machining Trends at IMTS 2022
Manufacturing businesses that machine parts in high volume are looking to new technology — hardware and software — to become more competitive.
Horn Supermini Set Offers Greater Holding Force
The Supermini toolholder system offers clamping carried out via a clamping wedge on the face.
Swiss-Type Lathe Runs 2-Inch Parts Complete
This Swiss-type multitasking machine does all the crosswork and endwork milling, drilling and tapping complete, and even engraving and deburring, on one machine.
