Distributed Control Network for Machine Tools
Marposs will introduce its new Blú distributed control network for machine tools.
Edited by
Marposs will introduce its new Blú distributed control network for machine tools. The system architecture enables real-time communication between internal and external machine functions.
The modular system is comprised of a central processing unit located in the machine’s control panel with compact nodes to control functions such as part flagging, gaging of electromechanical actuation and in-process measurement, acoustic emission sensing, wheel balancing, and process monitoring. All communication between the master processing unit and the functional nodes is handled by a single cable, which is said to simplify installation, maintenance and upgrading of the control system.
The system can be adapted for a variety of uses, from simple control applications to integrated production and control systems. The modular architecture enables users to modify the system according to their specific requirements by adding the necessary function nodes and the associated application software packages. The system features technical solutions for machine tools with the company’s current measuring and process control sensors.
Components of the system are designed to provide mechanical reliability and withstand challenging working environments, coolants, vibration and temperature variations as well as the presence of waste materials produced by the machining process.
Eural Free-Cutting, Lead-Free Aluminum Alloys
IMTS 2022: Eural has developed three new aluminum alloys lead free and tin free to meet regulations, while providing the same results in terms of productivity and efficiency.
Marubeni Citizen-Cincom Twin-Turret Lathes for Flexible Tooling
Miyano machines are designed to ensure high rigidity, high accuracy and long life.
Starrett's Multisensor Vision System Provides Large Field of View
IMTS 2022: The AVR-FOV 0.14X multisensor vision system is designed to provide accurate, efficient measurements fora wide range of parts.
