Home » Articles » High-Performance Tap
The MultiTAP is designed to cut a range of materials including carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze.
Article From: 6/18/2010 Modern Machine Shop
The MultiTAP is designed to cut a range of materials including carbon steel, steel alloys, stainless steel, aluminum, cast iron, copper, brass and bronze. The tap is designed to produce threads within both 2B and 3B classes of fit.
The tap is constructed of a grade of high speed steel (HSS-E), Nitrided with a Ne2 surface treatment. It is available in both spiral point and spiral flute configurations for through- or blind-hole applications. Tap sizes cover a full range for UNC or UNF threads, from #4-40 to ¾"-16" in inch sizes, to metric sizes from M4 × 0.7 to M16 × 2.0.
According to the company, the tap is designed for a job shop or a manufacturer that works with short- and medium-run threading applications across a spectrum of materials.
PMTS 2013
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
