Article From: 3/14/2011 Modern Machine Shop
A reader recently used the “Ask an Expert” feature of our Micromachining Zone to ask the following question.
Question
I am interested in getting a small machine and beginning a small business part-time from my home. With the space, power and noise restrictions in a residential area, I was wondering if micromachining would be a good option. Any thoughts and advice? What machinery would you recommend? Also, how do you pick up secondary setups on such small parts, and clamp without deformation?
Response from John Bradford, micromachining R&D team leader for Makino
Nice to receive this message. Generally speaking, from a support equipment and supplies standpoint, you will need to have the following items before you even consider the machine tool:
1. Inspection devices
Normally, there is not one specific instrument that will cover all of your measurement needs. Consider the following pieces as a necessity to get started: (1) toolmaker’s microscope or profile comparator for dimensional measurements, with magnification range 10x to 50x, and (2) stereo microscope, for part assembly and visual verification, with magnification range 5x to 25x.
2. Software
You will need a solid CAD system to perform basic design (Solidworks is great), and of course a flexible and intuitive CAM system (Mastercam is a good all-around system for 2D and some 3D work).
3. Quality tooling
This is an important point. Don't skimp on toolholders, as this provides the interface between the machine spindle and your cutting tools. If you go cheap here, you will have problems with tool wear, breakage and poor surface finish. Tooling to hold parts to the machine table is also important. We tend to recommend an integrated tooling system such as Erowa or System 3R for simple chucking and unchucking, without the need for re-setup for alignment and location.
4. Basic support equipment
Having a bandsaw and a Bridgeport-style mill are primary necessities, as you will find an ever-increasing need to produce basic fixtures, jigs and other accessories. The mill also doubles nicely as a drill press.
5. Toolmaker's tools
The pride of every toolmaker—dial indicator, micrometers, calipers, scale, sine plate and parallels are among the basics.
6. Machine tool
If you are starting off with a minimal investment, a Makino machine is overkill. Look at the Haas Office Mill. Look also at Microlution and Atometric machines, which are very small, quite flexible and will generally provide machining accuracies of 0.005 mm pretty consistently.
7. Part holding
My answer to your question will sound evasive, but your fixturing solution will vary as widely as the different parts you will be machining. Solutions may include Superglue, double-sided tape, epoxy, form machined flexure vises or a conventional toolmaker’s vise. This is where your experience and creativity will come in to play. There are no cookie-cutter answers to the question of holding small parts.
8. Web presence
How do you want to let the marketplace know about you? It would be wise to prepare a budget for creating an effective web site for promotion, as well as a means for your customer to contact you
9. Business plan
Take a few weeks and thoughtfully rough this out. The exercise will bring you face-to-face with the reality of what you will be entering into. (And your financier will need to have this if you wish to ask for capital!)
I hope this gives you a little more to think about. There are many things to consider: what markets to serve, how to promote yourself and what your limitations are (including time, tolerances, delivery and quantities of parts you would accept or not accept).
I wish you the best of luck to you in your potential new endeavor!
