Multi-Spindle Turning Center Boosts Productivity
Tornos Technologies’ MultiSwiss 6×16 turning center is said to achieve the same production rates as cam-type machines but with quieter operation.
Tornos Technologies’ MultiSwiss 6 × 16 turning center is said to achieve the same production rates as cam-type machines but with quieter operation. The machine features 14 linear axes and seven C axes, and can be equipped with additional Y axis. The seven independent spindles provide angular positioning and optimize speeds in each position. Each spindle has its own Z axis with hydrostatic bearings, enabling good surface finish and extending tool life by as much as 30 to 40 percent, the company says. The machine accommodates workpieces ranging to 16 mm in diameter and 40 mm long.
In addition to the MultiSwiss 6 × 16, Tornos is showcasing the Swiss GT 26 B seven-axis machine, SwissNano Swiss-type lathe, Swiss DT 13 high-performance Swiss-type lathe, EvoDeco 10 Swiss-type lathe, SAS 16.6 multi-spindle machine and Esco NM6 Flexi lathe.
Starrett's Multisensor Vision System Provides Large Field of View
IMTS 2022: The AVR-FOV 0.14X multisensor vision system is designed to provide accurate, efficient measurements fora wide range of parts.
Questions about Precision Machining? Ask Index
At this IMTS, Index Corp. is challenging show visitors to Ask Index key questions, the answers to which can help them ready their businesses for the next five years or more.
VR at UR: See Cobots in Another Dimension
Universal Robots’ expansive two-story IMTS booth in the North Hall features a VR headset interface that will give you exact tool and joint positions in real time as you manipulate the arm with the virtual gripper.
