Business for automatic bar feeders in general is good. As change-over concerns continue to infiltrate the precision parts manufacturing industry, many shops look to the automation potential of the PLC- or CNC-controlled bar feed unit to augment its production machine tools. The use of integrated control on automatic bar feeders enables them to function in concert with the machine tool rather than be subservient to the machine.
Equipped with magazine loaders that automatically replenish the feeder, these “accessories” can dramatically affect the uptime of capital equipment. On manned shifts, one operator can handle more machines at a time, and for lightly attended or lights-out operations, the carrying capacity of these bar feeders is required to produce the full run.
Bar feed manufacturers continue to do a good job addressing the issues of precision parts manufacturers. Today’s automatic bar feed unit is more reliable and has better range and more flexibility than ever before.
Much development work has been done to help shops change-over the bar feed from one stock size to another. Let’s look at one company’s answer to the problem.
Look Ma, No Guide Channels
The basic function of any bar feed unit is to deliver barstock to the machine tool’s work zone so parts can be cut. In a production environment, long barstock (12 feet) is efficient because numerous parts can be made from a single bar. Add to that the ability to reload the loader from a magazine, and it’s possible to supply material production over a long period of time.
Fundamental to the bar feeder is full length support of the bar as it rotates and a mechanism to push it into the machine as material progressively is used. Bar support is necessary to eliminate chatter that causes vibration and, in smaller diameters, whipping of the material as it is rotated by the machine spindle.
Guide channels are used to accomplish full length support of the bar in the feeder unit. All 12-foot long bar feeds use guide channels, or some variation of them, to support the bar.
The fit between the bar and guide channel is relatively close. Usually, when a bar size is changed the guide channels must also change to accommodate the new diameter or shape. This adds to the downtime of job change-over as well as creating the need to inventory various sizes of guide channels.
Instead of removable guide channels, Top uses a series of variable position steady rests to support the full length of the bar. They are a U-shaped rubberized plastic material that dampens vibration and noise. The bars rotate while being sprayed with oil inside the steady rests for lubrication.
When changing from one size bar to another, both the upper and lower steady rests move together to keep the bar on the spindle’s center line. Only one complete set of steady rests, comprised of six pairs of upper and lower rests, are needed for the full working range of a given bar feed model and support the entire bar length at all times during the machining process.
The adjustment mechanism for these rests is executed through the PLC input by programming the bar diameter or the maximum inscribed OD for non-round stock. Each new diameter is entered into the PLC, and it calculates the correct adjustment distance of the steady rests for bar diameter and centerline height.
The Pusher As Spindle Liner
Unless the barstock is very close in diameter to the machine tool’s spindle bore, spindle liners are traditionally used to take up the distance variation between bore and bar. These liners, in effect, function as guide channels when the barstock length can no longer be supported inside the bar feeder. Obviously, changing spindle liners and inventorying them adds to the time and cost of job change-over.
Instead of spindle liners, Top uses the bar pusher itself to support the bar once the pusher enters the spindle bore. Basically, this is accomplished by customizing the pusher OD for the specific ID and length of the spindle bore it is attached to. A rotating bearing is fit to the stationary pusher nose for close support in the spindle bore and smooth operation as the bore rotates around the centerline of the pusher.
In effect, once inside the spindle bore, the bearing on the pusher and the collet/chuck on the machine spindle support the bar at both ends, allowing remnant retraction when this option is used. Pushers are interchangeable if the bar feeder needs to be applied to a different size machine.
Hang On To That Bar
Sometimes simple is better. In operation, the barstock and pusher need to be connected. This performs at least two functions.
First, it enables the feeder to precisely move the bar axially within the programmed distance without overshooting. Second, it allows automatic withdrawal of the spindle remnant so no short parts are made and production is uninterrupted. Front or rear remnant ejection can be programmed into the PLC.
For the connection between the bar and pusher, Top uses an “emergency” collet. This collet is made from a vulcanized material that can be quickly bored to the bar diameter needed. A simple, quick disconnect pin secures the collet to the pusher.
The collet grips the bar with sufficient pressure to maintain a solid connection between the bar and the pusher. By keeping a few of these relatively inexpensive collet blanks on hand for when a quick turnaround is needed, the collet can be bored to exact bar size and installed in minutes rather than waiting on a conventional collet to be made or shipped.
It’s About Quick Change
The economics of the precision turned parts industry are changing. This is not news to those involved in the business. Shops today are looking at different metrics to measure the effectiveness of production.
Capital equipment usage is a key measurement for productivity. Cycle time alone is insufficient to gage how well or poorly a job is being run. Today, it is necessary to look at workflow and throughput to get a more accurate picture.
The speed at which jobs can be turned is decreasing and with developments in progress by builders and suppliers as well as shops themselves, this trend will continue. Automation of the production process coupled with quick-change innovation are important cogs in this wheel.
New Kid On The Block
Networking is a critical tool for most companies and individuals involved in manufacturing. While what you know is extremely important, who you know and, more to the point, knowing who has the information you need is how business gets done.
This is especially true in trade magazines. Since Production Machining began in 2001, we’ve been blessed with a strong association with the Precision Machined Products Association (PMPA) (see pages 15-20). Invariably, the association’s staff will answer all of your questions. As for me, the PMPA proactively alerts me to article leads that may be of interest to you, the magazine readers.
Italian bar feed manufacturer, Top Automazioni N.A., understands the importance of PMPA as well. After setting up distribution in the United States through Precise Solutions (Brooksville, Florida), it quickly joined the PMPA as a technical member. After a heads-up from PMPA, I called Top immediately to introduce myself and the magazine.
Timing is important, and as luck would have it, Top scheduled a factory open house for Eurotech’s U.S. distributors right before I was scheduled to be in Europe. That’s how I ended up on a plane to Italy to visit the company and meet its founder and owner, Bruno Bargellini. The company is located near Bologna.
