Tooling Package for Increased Productivity
GenSwiss offers its Lous Belet SA precision carbide Expert series tooling packages designed for aluminum, brass, titanium, stainless steels and composite material groups.
Edited by
GenSwiss offers its Lous Belet SA precision carbide Expert series tooling packages designed for aluminum, brass, titanium, stainless steels and composite material groups. The packages incorporate improved geometries and coatings for drills, end mills, slotting saws, thread mills, engraving and spotting tools. The series is designed to increase productivity, remove material at higher rates, improve surface quality and extended tool life over a range of industry applications within the material groups.
The company will also feature its Utilis Multidec Cut3000 cutoff inserts with new geometries.
Marubeni Citizen-Cincom Twin-Turret Lathes for Flexible Tooling
Miyano machines are designed to ensure high rigidity, high accuracy and long life.
Emag VT 4-Axes Lathes for Shaft Production Maximum Performance
IMTS 2022: The lathes are said to provide short cycle times, high-precision machining and safe processing with the VT series of turning machines literally turning the classic horizontal machining process on its head.
Horn Supermini Set Offers Greater Holding Force
The Supermini toolholder system offers clamping carried out via a clamping wedge on the face.
