Turn-Mill Center Supports Automation Integration
Emco Maier’s Hyperturn 45 turn-mill center is designed for applications in automotive and general engineering.
Emco Maier’s Hyperturn 45 turn-mill center is designed for applications in automotive and general engineering. The turn-mill offers a Y axis with a 70-mm traveling distance in the upper carriage system and a Z2 axis in the lower. Water-cooled main and counter spindle motors are designed to provide a higher drive power of 15 kW, a maximum speed of 7,000 rpm and 100 Nm of torque. The machine features a thermo-symmetrical machine construction with a three-axis portal to enable automated loading and unloading as well as potential access to separate deburring and cleaning stations. It is equipped with a Siemens Sinumerik 840D-sl control and drive system plus a fold-out PC keyboard.
The turn-mill will be featured as part of a cell with a Renishaw Equator dimensional gaging system, a part-handling system, and a FANUC CR-35iA collaborative robot with a lift capacity of 35 kg.
What Is The Best Bar Feed System For Production Turning?
Selecting the right bar feeder can be one of the most important decisions a shop can make. Bar feed systems help improve productivity, throughput and quality, but in order to achieve the most benefit from them it is essential that a bar feed system be matched to the particular needs of the turning operation.
Smart Workholding Device Measures and Monitors
Sensor and IIoT technology combine to enable these chucks and mandrels to automatically monitor workholding parameters and measure part features to ensure process stability.
The Many Sides of Workholding
