Home » Articles » Turn-Mill Designed For Parallel Use
Index’s R200 turn-mill center features two motorized milling spindles that can perform in two independent sub-systems, including five-axis machining.
Article From: 3/10/2010 Modern Machine Shop
Index’s R200 turn-mill center features two motorized milling spindles that can perform in two independent sub-systems, including five-axis machining. Both heavy-duty roughing operations and accurate fine-turning operations can be performed simultaneously on the main spindle and counter spindle. The parallel use is designed to increase productivity.
