Vision Numerical Control for High-Speed Milling
Fidia will feature its C-40 vision numerical control for advanced high-speed milling and multi-axis applications.
Edited by
Fidia will feature its C-40 vision numerical control for advanced high-speed milling and multi-axis applications. The control is equipped with a Quad-core processor and more powerful graphic processor. The product’s 64-bit, Windows 7 operating system enables precise execution and virtual machining of the tool path using the Fidia ViMill system. The control on display will be equipped with a V5 software package for multi-axis control that is designed to improve the performance of high-speed milling machines.
See Chip Control and Chipless Cutting at Marubeni Citizen-Cincom
Visit Marubeni Citizen Cincom’s booth to see how the new Low Frequency Vibration (LFV) cutting technology deals with the problem of chip accumulation.
Starrett's Multisensor Vision System Provides Large Field of View
IMTS 2022: The AVR-FOV 0.14X multisensor vision system is designed to provide accurate, efficient measurements fora wide range of parts.
Emag VT 4-Axes Lathes for Shaft Production Maximum Performance
IMTS 2022: The lathes are said to provide short cycle times, high-precision machining and safe processing with the VT series of turning machines literally turning the classic horizontal machining process on its head.
