5/23/2019 | 3 MINUTE READ
3 Mindset Changes for Lights-Out CNC Machining
Originally titled '3 Mindset Changes for Lights-Out Machining'
Facebook Share Icon LinkedIn Share Icon Twitter Share Icon Share by EMail icon Print Icon
Expanding capacity into the unattended hours calls for counterintuitive new ways of thinking about the work.
For many machine shops today, the most promising avenue of potential expansion is not a new market or an addition to their facilities, but instead the untapped, unstaffed nighttime hours that could be captured for automated, “lights-out” production.
The daytime hours are generally full. Their limit is imposed by staffing. Shops with resources to expand are often challenged to find or develop personnel to keep pace. The answer, then, is equipment with less need for personnel—machines that can run unattended long after the staff has gone home. For many shops, though, equipment such as this represents a new and different type of machine tool than what the shop is accustomed to running, and using the equipment well calls for different assumptions.
Matsuura has seen this. The company supplies machining center systems served by automation. During a recent visit to the company’s U.S. headquarters in St. Paul, Minnesota, I saw examples new to the North American market and discussed how machines such as these differ from the equipment common in many shops. The most widely established type of CNC equipment is, of course, the small, standalone, three-axis vertical machining center (VMC)—a machine type that is challenged to realize any significant extent of unattended production. An operator typically needs to remain close to this type of machine, if only to keep feeding it new workpieces. By contrast, a machining center better suited to realize significant unattended production combines five-axis or five-sided machining to complete or nearly complete a part in a single cycle, along with pallet loading in order to enable a queue of work to be set up and staged for the machine. Matsuura’s U.S. president Craig St. John says demand for automated machining centers such as this has never been higher, but making full use of this type of machine requires a mindset shift in shops where machine tools generally run in proximity to a person.
Here are three counterintuitive ideas Mr. St. John and others with the machine tool company say might need to become second nature:
1. Run simple parts on high-end machines
“Keep it simple,” says Matsuura product manager Tyler Bonde. For a smaller shop buying a five-axis, pallet-fed machining center for the first time, this automated machine is likely to be the shop’s most expensive resource. The standard expectation says a high-value machine tool ought to run high-value parts. But this is potentially the wrong way to think about unattended machining, he says. In this case, the high-end machine tool likely should run the simplest parts. That is, it should run all the parts best able to run trouble-free without any operator nearby.
“Not every job is a candidate for unattended machining,” Mr. Bonde says. Some involve uncertainties or challenges that call for an operator to be close. “Run these jobs by day,” he says—possibly on less automated machines. The shop can then fill the nighttime hours with more straightforward and simple work, even if those parts are less valuable. Low-value work is frequently where automation makes its highest impact.
2. Slow down to do more
On a standalone machine tool, cycle time is key. But on an automated machine tool running unattended, reducing cycle time might no longer be the most productive aim.
“For automated machining, it’s not how quickly you can make a part,” says regional sales manager Fernando Garcia. “It’s what level of throughput you can maintain for a given availability of time.”
The distinction is subtle but important. The difference is consistency. The throughput for a given unattended time window might be lost if some unexpected event, notably a tool breaking, stops the machine while no one is around to restart it. Mr. Garcia says minimizing the likelihood of events such as this is pivotal for successful unattended machining, and achieving this level of reliability frequently involves slowing down so that the machining process is stable and tool wear is as predictable as possible. The side benefit of this is that both tool costs and scrap rate are liable to go down.
3. Find the most profitable hours after dark
Once a shop becomes established running productively without staff present, “You’ll want to run unattended all you can,” Mr. St. John says. In fact, the reasons go beyond the opportunity to find additional capacity. Another reason is that this capacity is almost certain to represent the shop’s least expensive machining work. Labor is a large portion of the cost of any part run in a process that requires an operator. Shops seeking to expand profitability thus have the equivalent of a low-cost alternate source to which they can turn. This low-cost provider is not an external subcontractor willing to do the work cheaply, but instead the same shop running differently during the part of the day when less labor is present.
  • Keeping Watch on Small Parts
    From watch parts to exotic medical applications, this shop takes on the world of micromachining.
  • Get Five-Axis Machining on a Three-Axis VMC
    Machine shops want and need to eliminate steps in the manufacturing process. Adding four- or five-axis capability to an existing three-axis VMC is a practical way to achieve five-sided machining using a single setup.
  • The Pursuit of Perfection
    The “Pursuit of Perfection” is how Acero Precision defines its mission and while such lofty words make nice copy, all one needs to do is visit this contract manufacturer to experience how serious the company is about the technology, personnel and processes necessary to make it more than an abstract goal.
Resources
