#pmpa
How Are Steel Bars Cold Drawn?
Hot-rolled steel bars, either in cut lengths or in coils, are first cleaned by shot blasting or acid pickling to remove the hard abrasive oxide scale on the surface. Then they are pulled through a carbide die in the presence of high-pressure lubricants which reduces the bar’s cross section. This process is called cold work (no heat is added in the process). The cold work trues up shape and holds diameter size to a very tight tolerance. The process also improves strength (increasing both yield and tensile strength) and hardness while reducing ductility (% elongation and % reduction in area). The drawn bar is then straightened and cut to length, followed by further testing for surface imperfections, if specified. Bars then have rust preventive applied and are packaged and labeled for shipment.
Why Cold-Drawn Steel Bars?
The process of cold drawing is done at ambient temperatures and transforms the material properties by a process called cold work. This cold work increases yield strength substantially; the tensile strength somewhat; as well as the hardness. At the same time, the ductility is reduced, which improves the steel’s machinability. Because the cold drawing work is done at ambient temperatures, the tolerance achieved for size and out-of-round is held to just a few thousandths of an inch.
By convention, tolerances are held to the minus, nothing to the plus. This makes loading into workholding more convenient, and the material diameter and shape are often useable as is for many mechanical components.
Specifications for Cold Drawn Carbon and Alloy Steel Bars
Cold drawn carbon and alloy steel bars are specified in ASTM A 108 Steel Bar, Carbon and Alloy, Cold-Finished. Size tolerances for Level 1 Carbon Steel Cold-Finished Round Bars (Cold Drawn, or Turned and Polished) can be found in Table A1.1 of ASTM A108. For alloy grades, the size tolerances are found in Table A1.2. Tolerances are based on bar diameter, and carbon content and thermal treatment
The reasons to select a cold-drawn steel bar are few but compelling:
- The hard abrasive scale has been removed — preserving tool life as well as metalworking fluid utility. The cold drawing operation improves the as-received surface finish of the bar.
- The cold-working strain imparted by cold drawing improves the machinability of the material (not only the ease of removal of chip but also the resulting surface finish.)
- The tight dimensional and out-of-round tolerance may result in a reduction in processing needed.
- The straightness (lack of runout) as well as the better concentricity and dimensional tolerance enables higher rpms. The higher surface feet per minute increases output.
- The higher mechanical properties mean that the part may withstand higher stresses and forces in the customer’s application. This makes cold-drawn steel bars ideal for shafting and power transmission applications.
- Standard grades are widely stocked and available for prompt delivery.
While the cold-drawn bar as shipped has a bright, smooth, workmanlike surface (since no stock removal was taken), it is not warranted for surface finish. However, the bright drawn finish is often suitable without any additional processing. Typically, surface finish is in the neighborhood of 125- 32 microinches using normal processes. (Machinery’s Hand-book) However, many of today’s mills have specialized processes that can deliver better.
What don’t you get with cold drawing? As no stock removal has been taken, there is still the possibility of seams and other surface imperfections. This possibility increases when the steel is resulfurized. While the sulfur promotes better machining, it also increases the possibility of seams and other surface imperfections.
ASTM A 108 table A1.8 provides the surface discontinuity tolerances for carbon and alloy bars, based on sulfur content and bar diameter.
Material may be in stock available for prompt delivery. Finally, a less important but often overlooked factor is that cold-drawn steel bars are the most widely used feedstock in most of our precision machining shops. As a standard raw material, produced to standards for chemistry and tolerances, our shops are able to gain experience and understand what to expect when ordering cold-drawn bars.
Cold-drawn steel bars cost more than hot-rolled steel bars of the same grade, due to cost of manufacturing as well as yield loss in the manufacturing process. However, the benefits afforded to our precision machining shops are the absence of hard abrasive oxide scale, improved mechanical properties which lead to better machinability, improved dimensional control, concentricity, surface finish and straightness.
It is easy to see the benefits of using cold-drawn steel bars outweigh their increased cost of production. Careful handling will preserve surface finish and straightness, minimizing perishability of quality. It is no accident that cold-drawn steel bars are a preferred material for many precision machined components. Now you know some of the reasons why.
Read More Articles from PMPA:
- The Battle for Performance: Efficiency Versus Effectiveness
- Craftsman Cribsheet No.116: Twist Drills for Success
About the Author
Miles Free III
Turned and Polished Steel Barstock: How It Is Manufactured, How It Impacts Your Shop
Precision Ground Barstock: How It Is Manufactured, Benefits to Your Shop
The Value of Auto Adjust Magazine Bar Feeders
This bar feeder is designed to offer the flexibility to enable CNC turning centers to perform short-run work that would otherwise require frequent setups over a range of barstock diameters.
