Craftsman Cribsheet No. 105: Yield Loss Due to Bar End Remnants
Yield loss on raw materials can become a hidden way of losing money in your shop. Using a chart and sample calculations can help you better understand why you might be better off buying longer bars for your process to reduce yield loss dollars.
#pmpa
As material costs continue to rise (Producer Price Index shot up 9.7% January 2021-January 2022), yield loss on our raw materials can become a hidden way of losing money in your shop. Use the chart and sample calculations to better understand why you may be better off buying longer bars for your process when available to reduce yield loss dollars.
- Minimizing the length of the bar end is important, but due to fixed bar length availability from our suppliers, it may be difficult for us to control.
- One way to minimize the loss due to bar ends is to purchase the longest bars that your process can accept. This lowers the percentage loss for a fixed length of bar end.
- Another way to minimize bar end loss could be to reduce cutoff tool width, which may enable additional parts to be produced, reducing the length of the bar end.
Percentage Loss Due to Bar Ends
Example: Increasing Bar Length
A 5-inch bar end is required by your equipment. The material price is $0.795 per pound. You are ordering 10,000 lbs of bars for the job.
The cost of yield loss for 10-foot material given a 5-inch bar end is 4.17% times 10,000 lbs times $0.795 = $417
To calculate the savings by using longer bars, subtract the new yield loss from that of the 10-foot bars.
Increase bar length from 10 feet to 12 feet
- Yield loss on entire lot if 12-foot bars: 10,000 pounds times .0347 times $0.795 = $347
- Increasing bar lengths from 10 feet to 12 feet saves the company $417 minus $347 = $70 of unneeded yield loss.
Increase bar length from 10 feet to 16 feet
- Yield Loss on entire lot if 16-foot bars: 10,000 lbs times .0260 times $0.795 = $260
- Increasing bar length from 10 feet to 16 feet saves the company $417 minus $260 = $157 of unneeded yield loss.
Increase Bar length from 10 feet to 20 feet
- Yield loss on entire lot if 20-foot bars: 10,000 lbs times .0208 times $0.795 = $208
- Increasing bar lengths from 10 feet to 20 feet saves the company $417 minus $208 = $209 of unneeded yield loss.
Using longest lengths of bar stock available can reduce your yield loss due to bar ends substantially.
Precision Machining Jobs Account for 7 of the Top 25 High Paying Jobs — No College Degree Required
Those who hire in the precision machining industry have a persuasive point for prospective employees who don’t hold — or want to go into debt to hold — a college degree.
Steel Defects Seams on Rolled Steel Products
Learn how to detect and avoid defect seams in rolled steel products.
Steel Defects Slivers on Rolled Steel Products
Steel defects slivers are, by their very nature, “injurious defects,” and as such rejectable.
