It’s time to reconnect with the precision machined parts community at the Precision Machining Technology Show (PMTS) 2023 set for April 18-20, 2023, in Cleveland, Ohio, at the Huntington Convention Center. It’s the perfect opportunity to consider investing in updates for your company’s technology, automation and software to make your business more efficient and productive.
Production Machining wants to help kick off your research with a series of PMTS Product Previews. In this group, we’re taking a look at cutting tools, including a deburring tool for consistent deburring of even and uneven bore edges, a cutting concept performing multiple functions as one tool, a micro endmill for difficult-to-machine materials, and more.
Before you go to the show, don’t miss PMTS show highlights in Derek Korn’s PMTS feature article and look for more PMTS Product Previews each week until the show! And don’t forget to register for the show.
Also, you can simplify your visit to PMTS 2023 by utilizing the “My Show Planner,” which combines planning and logistics into one easy-to-use tool.
Read MoreAir-Actuated Back-Spotfacing is Now an Option
A coolant-actuated, back-spotfacing tool design is now available in an air-actuated version for machines that don’t offer through-tool coolant delivery or parts that can’t be machined using coolant.
Read MoreRepeatability and Rigidity Are Key for Quick-Change Swiss Tooling
Read MorePMTS 2023 Product Preview: Measurement
