Hydraulic Roll Marking Machines
The water-based degreasing/cleaning system does not require line maintenance shutdown, periodic pumping or solvent replenishment. The system is suited for parts cleaning prior to plating, painting, powder coating or hot dipping. The process uses microorganisms that consume oils and fat substances present on parts.
The water-based degreasing/cleaning system does not require line maintenance shutdown, periodic pumping or solvent replenishment. The system is suited for parts cleaning prior to plating, painting, powder coating or hot dipping. The process uses microorganisms that consume oils and fat substances present on parts. BioClean, (203) 367-0663, fax: (203) 367-0396.
Learn More
