End Mill Series for Chatter-Free Machining
Haimer USA’s will display its newly expanded offering of Power Mill end mills.
Edited by
Haimer USA’s will display its newly expanded offering of Power Mill end mills. The series is made from K20-K40 grade fine grain carbide developed to be matched with the company’s toolholders. The end mill’s geometries utilize flute and helix designs to provide chatter-free, high-end machining.
The series is equipped with integrated Safe-Lock shanks for optional use with the Safe-Lock toolholding technology. Its variable-helix design provides vibration-free machining and a runout accuracy of less than 0.0002". The machines are precision-ground and fine-balanced for consistent and repeatable performance, and maximum metal removal rates. Expanded offerings are available in inch and metric sizes.
The company will also be exhibiting its Duo-Lock modular interface for carbide cutting tool heads and the Safe-Lock tool clamping system. Additionally, the company will display its Power Clamp shrink-fit machines; shrink-fit toolholders and collet chucks; Tool Dynamic balancing machines; 3D sensors; and Cool Flash coolant delivery system.
Marubeni Citizen-Cincom Twin-Turret Lathes for Flexible Tooling
Miyano machines are designed to ensure high rigidity, high accuracy and long life.
Emag VT 4-Axes Lathes for Shaft Production Maximum Performance
IMTS 2022: The lathes are said to provide short cycle times, high-precision machining and safe processing with the VT series of turning machines literally turning the classic horizontal machining process on its head.
Questions about Precision Machining? Ask Index
At this IMTS, Index Corp. is challenging show visitors to Ask Index key questions, the answers to which can help them ready their businesses for the next five years or more.
