Multitasking Turning Centers Enable Heavy-Duty Machining
Methods Machine Tool introduces the Nakamura-Tome NTRX-300 multitasking turning center.
Methods Machine Tool introduces the Nakamura-Tome NTRX-300 multitasking turning center featuring true opposing twin spindles that can be equipped with 8" A2-6 25-hp or 10" A2-8 30-hp spindles. The machine also features a 25-hp tool spindle with 12,000 rpm and full five-axis capabilities with FANUC 31I A5 control. The Y-axis travel measures 10" (250 mm) while the below-center X-axis travel measures 5" (125 mm). The NTRX-300 is available in two models, with 8" (203-mm) chucks and 2.5" (63.5-mm) bar capacity or with 10" (250-mm) chucks with 3.15" (80-mm) bar capacity.
The series features a bed design with a vertical column structure mounted on a horizontal machine bed for rigidity and thermal stability. Machines are equipped with CAMplete TruePath Turn/Mill software as well as Nakamura-Tome (NT) Smart X Operation Software, which offers an operation-level management function to view operator clearance level; a productivity monitor function showing the status, productivity graph and capacity utilization of the machine; and a loading monitor function that provides detailed load information. An NT Collision Guard feature protects against machine collision and includes an air bag function to minimize damage in the event of a collision. Voice guidance, production management and 3D collision check are also included.
Horn Carbide Grades for High-Feed Milling
IMTS 2022: The SC6A and IG6B grades complement the tool system for high-feed milling and enable customers to choose the grades best adapted to their machining applications.
See Orange County Chopper’s Hydromat Anniversary Motorcycle Today
As part of its upcoming 40th anniversary celebration, Hydromat engaged Orange County Choppers (OCC) to build a custom motorcycle to celebrate this milestone, with OCC’s founder Paul Teutul Sr. at the event for the unveiling.
VR at UR: See Cobots in Another Dimension
Universal Robots’ expansive two-story IMTS booth in the North Hall features a VR headset interface that will give you exact tool and joint positions in real time as you manipulate the arm with the virtual gripper.
