Quick-Change Tool System Reduces Setup Time
Benz’s Solidfix modular tool-changing system is designed to enable quick tooling changes via adapters that hold a variety of tools.
Edited by
Benz’s Solidfix modular tool-changing system is designed to enable quick tooling changes via adapters that hold a variety of tools. According to the company, the quick-change system enables users to preset tools for precise, repeatable cuts, with tool changes in 15 sec.
Instead of traveling to a tool-changer rack, the Solidfix spindle can be programmed to move to a home position where the operator can quickly change tools and resume manufacturing. This helps reduce setup time by 90 percent and enables users to produce additional parts every day, the company says. Its rigid, compact, balanced design also provides large multi-surface contact with high-torque and high-speed performance.
The company will also display its LinA broaching tool system, crown gear technology for heavy-duty machining, and adjustable angle heads for machining difficult angles.
Customizable CNC Machine, Automation Solutions
IMTS 2022: BA W08-12 is designed for machining large workpieces made of aluminum and other nonferrous materials.
5 High-Volume Machining Trends at IMTS 2022
Manufacturing businesses that machine parts in high volume are looking to new technology — hardware and software — to become more competitive.
Swiss Machining Demo Shows Off Carbide Cutting Tool Lines
Pilot Precision, Palbit’s exclusive U.S. distributor, showcases Palbit’s cutting tools as well as its own broaching and drilling products.
