centroteX quick change-over system on machine
Every month, we’re putting together a Technology Showcase to highlight new product information that PM has received from supplier companies. For the latest new products across the broad spectrum of precision machining, check out Production Machining’s New Products online.
If you would like to learn more about the latest news, product technology and operational best practices in the precision machining industry, consider subscribing to Production Machining’s free monthly print magazine.
Read PM’s Precision Machining Technology Review December 2024.
Forkardt Hardinge Swiss Workholding Provides Reliable, Consistent Performance
Swiss tooling group
Source: Forkhardt Hardinge
Forkardt Hardinge’s Swiss collets are designed to provide optimized concentricity and gripping strength for Swiss-style machines. These collets are said to securely hold parts without marring surfaces, minimizing vibration to ensure smoother machining, enhanced accuracy and extended tool life. Designed with precision in mind, collets and guide bushings feature enough spring draw to handle slight diameter variations in bar stock, providing reliability and consistency, the company says.
Sandvik Coromant ATC System Boosts Machine Utilization
ATC on turning machine
Source: Sandvik Coromant
Sandvik Coromant is introducing an automatic tool change (ATC) system for its machine-adapted clamping units (MACU) in turning centers. This specialized solution enables unmanned production, free from manual handling, for improved machine utilization and increased output, the company says.
In complex part production, the time-consuming process of manual tool changes often results in low utilization of turning centers. Sandvik’s ATC solution for machine-adapted clamping units addresses this issue by enabling full automation in turning centers. ATC for MACU is said to eliminate the need for manual handling, resulting in higher machine utilization and increased productivity. Furthermore, complex part production becomes more efficient with an ATC-enabled turning center, streamlining the manufacturing process.
Heule Cutting Tool Provides Chatter-Free Countersinks
Heule Precision Tools’ GH-K tooling provides precision, chatter-free countersinks in a wide range of materials. Engineered with a positive geometry for high-shear cutting action, it features carbide blades for machining cast iron, steel, aluminum and nonferrous materials, with optional HSS-Cobalt coated blades for steel and stainless-steel applications. Three-bladed tools are supplied for manual or CNC applications; single-bladed tools for all machining centers.
As the tool is fed into the part, the blades start cutting once the tip contacts the material. The operator continues to feed the tool until the desired countersink size is achieved, then rapidly retracts the tool. The GH-K’s shallow radial clearance is said to ensure precision and chatter-free operation, although controlled feed rates may be necessary. Shims can be added to adjust the tool’s performance for more aggressive feed rates.
Supertec Machinery ID/OD Grinder Reduces Setup Times
Grinding machine
Source: Supertec Machinery
Supertec Machinery’s PMGII-150CNC is a turret-type multispindle ID/OD grinder. The PMGII-150CNC features a between-centers distance of 1,500 mm (60") and a 380-mm (15") diameter working capacity, making it one of the largest capacity turret type ID/OD grinders on the market, according to the company.
The PMGII-150CNC comes with a 20" plunge-type OD wheel, a 16" angle-head OD wheel and an optional rpm ID spindle, which enables a wide range of grinding capabilities. With a turret design having the capability of three grinders in one, the PMGII models can reduce setup time and improve overall cycle times on complicated jobs. Also combining three spindles onto one machine enables the PMGII models to minimize floor space for other requirements.
Tungaloy Milling Tool Provides Enhanced Edge Strength
Milling tool
Source: Tungaloy Corp.
Tungaloy Corp.’s MillQuadFeed series includes flat-top inserts with enhanced edge strength. These inserts come in two variations: the Z-type for versatile use and the U-type for small entry angles, providing improved durability and stable performance in challenging machining environments, such as interrupted cutting and machining of hardened materials.
The MillQuadFeed cutting tool combines low cutting resistance with high rigidity through its hybrid design, providing reliable performance in heavy-duty machining. It features a specialized insert geometry that is said to reduce cutting resistance by up to 20%, enhancing machining efficiency. Suitable for a wide range of applications such as shoulder milling and plunging, MillQuadFeed also provides double the tool life compared to conventional tools, according to the company.
Precision Meets Productivity
Nakanishi EmaxEVOlution Micro Grinder
AS5202 or SAE J1926 Port Kits by SCT
Grinding
Studer Motion Meeting 2026 Emphasizes Strong Foundations
At its 2026 Motion Meeting, Studer celebrated 50 years of its machine foundations, plus a new inexpensive machine and a thriving apprenticeship program. Read on to learn what machine shops can take away from the event.
Grinding
Building a Profitable Grinding Niche
By building processes for its niche, rather than a general manufacturing approach, Grind All has developed an unusual (yet profitable) value proposition.
Precision Machining Technology Review: April 2025
Production Machining’s April 2025 technology showcase includes some of the latest technology from Sumitomo, Hurco, Supertec, SMW Autoblok, SW North America and Tungaloy.
Grinding
Precision Machining Technology Review: March 2025
Production Machining’s March 2025 technology showcase includes some of the latest technology from Allied Machine and Engineering, United Grinding, HCLSoftware, Sandvik Coromant and Sunnen Products Co.
WEBINAR: From Machine Data to Guided Action: How Modern Shops Are Closing the Execution Gap
  In this webinar, MachineMetrics Product Manager Josh Fish is joined by Pindel Global Precision's Thomas Deslongchamps, for a candid look at what closing the execution gap actually looks like inside a precision machining shop.
Automation
Webinar Recap: Streamlining Swiss Machining Through Automation
See how CAMWorks 2026 cuts Swiss-style CNC programming time by 70%+ with automatic feature recognition, full machine simulation, and smart segmentation tools.
