Max Value
Precision-Driven Performance
Sponsored Content
Superion solid carbide tools for Swiss applications.
In Swiss-style machining, success hinges on efficiency, accuracy and repeatability. With tight part envelopes, long cycle times and demanding material requirements, there is no margin for tooling error. That’s where Superion — a subsidiary of Allied Machine and Engineering — brings measurable value.
Designed for high-performance holemaking, Superion solid carbide tools offer material-specific geometries, application-tailored coatings and customizations with steps — all of which solidify their track record of increasing productivity while reducing cost per hole.
Superion Swiss machining solutions are available in a range of materials and geometries. Source, all photos: Allied Machine and Engineering
At the core of Superion’s Swiss machining solutions is the understanding that no two holes — or materials — are the same. To that end, Superion provides a range of geometries optimized for specific material groups from stainless steels and high-temperature alloys to hardened steels and aluminum. These cutting geometries are paired with coatings engineered to enhance tool life, resist heat and ensure stable chip evacuation.
Engineered Geometries for Demanding Materials
Superion tooling is purpose-built to meet the complexities of Swiss operations. Each cutting geometry is designed with a specific material group in mind, including:
  • stainless steels
  • HRSA materials
  • cast iron
  • aluminum
These tools incorporate optimized edge preps and are paired with Allied’s advanced coatings, which offer exceptional wear resistance and thermal stability.
Swiss-type lathes demand tools that provide both tight tolerances and high repeatability. Superion delivers on both fronts with unique geometries such as:
  • HPM and HPS: Enhanced chip control and corner strength for carbon and alloy steels.
  • HPM2M and HPS2MDouble-margin designs for deep or interrupted holes, improving hole tolerance at depths beyond 8xD.
  • HP106Straight-flute, single-margin design ideal for hardened steels.
  • HPF: Tailored for aluminum with high-lubricity TiCN coating and improved chip evacuation.
    The Superion solid carbide drill with HPF geometry has a high lubricity TiCN coating for use in cast or wrought aluminum.
Step Tools for Swiss Efficiency
What sets Superion apart in Swiss machining is the focus on custom step tools.
These advanced tools combine multiple features into a single setup, reducing the number of tool changes required and significantly increasing throughput. For manufacturers, that translates directly to lower cost per hole and greater profit potential— without sacrificing precision.
Tailored Tooling, Tangible Results
Superion tools are not off-the-shelf solutions — they’re engineered answers to real machining challenges. Every Superion tool is produced in a purpose-built manufacturing facility, ensuring repeatable accuracy from short-run custom orders to high-volume production. Whether a customer needs 10 tools for a prototype run or a thousand for full-scale production, Superion delivers consistency and speed without compromise.
Add to that the industry expertise of Allied Machine and Engineering, and you’re not just buying a tool — you’re getting a partner in production. Together, they ensure your holemaking process is fine-tuned for performance and profitability, no matter the complexity.
Take Control of Swiss Machining Performance
In Swiss machining, where space is limited and cycle times matter, Superion solid carbide tools represent a high performance solution engineered for reducing cycle time, improving hole quality and increasing tool life.
Ready to optimize your Swiss machining process? Discover the power of Superion solid carbide tools—where precision meets performance.
CERATIZIT
MaxValue
Cogsdill single pass deburring at the spindle!
Parts Cleaning Conference 2026
IMTS 2026
Top Shops Conference 2026
iSpeed3
Tungaloy-NTK
SD-26S
T-A Pro
Davenport Machine
CERATIZIT
