Max Value
Every month, we’re putting together a Technology Showcase to highlight new product information that PM has received from supplier companies. For the latest new products across the broad spectrum of precision machining, check out Production Machining’s New Products online.
If you would like to learn more about the latest news, product technology and operational best practices in the precision machining industry, consider subscribing to Production Machining’s free monthly print magazine.
Read PM’s Precision Machining Technology Review April 2026.
Okuma Coolant System Enhances Chip Evacuation, Tool Life
Coolant system
Source: Okuma America Corp.
Okuma America Corp. expands its line of peripheral products to enhance manufacturing systems offerings. The Okuma High-Pressure (OHP) coolant system provides variable‑flow, high‑pressure coolant delivery to Okuma machine tools. The system is designed to provide optimal chip evacuation, extended tool life, improved surface finishes and enhanced productivity for modern manufacturing operations. Its robust construction and advanced filtration make it well-suited for a wide range of tooling sizes, multiaxis lathes, multifunction machines and machining centers.
The Okuma OHP system is compatible with water‑based coolants and suitable oils, making it versatile for a wide range of shops and applications. A dirty filter alarm alerts operators when service is required, helping protect tooling and maintain consistent performance.
Tungaloy Inserts Provide Consistent Performance in Complex Turning Operations
Cutting tools
Source: Tungaloy-NTK America Inc.
Tungaloy Corp. expands its Y-Pro Series with the addition of precision-ground YCGT inserts featuring a 25-degree corner angle for enhanced profiling and undercutting performance.
The Y-Pro Series is well-suited for complex turning operations such as profiling, undercutting and V-groove machining. Its specialized 25-degree corner angle design enables high-precision machining while avoiding interference. It is also compatible with multitasking machines and automatic lathes.
Kyocera Threading Tools Provide Efficient Production of Small Parts
Cutting tool
Source: Kyocera SGS Precision Tools
Kyocera SGS Precision Tools’ TW Series thread whirling tools are designed for high-efficiency thread production in precision small-part machining.
Well-suited for manufacturing critical components such as medical bone screws, the TW Series is engineered for Swiss-type lathes and supports a wide range of thread forms. Compatible with leading machine platforms including Citizen, Star and Tsugami, the system provides reliable, consistent thread generation for demanding industries such as medical and aerospace, where precision, surface finish and process stability are essential.
Mitutoyo Shopfloor CMM Features Temperature Compensation
CMM
Source: Mitutoyo America Corp.
Mitutoyo America Corp.’s Crysta-Apex V Plus Series CNC CMM is engineered to bring high-accuracy measurement directly to the production floor.
Evolving from the Crysta-Apex V500, V700 and V900 models, the Crysta-Apex V Plus Series combines advanced temperature compensation and an energy-saving, sustainable design to provide stable, precise results in real-world manufacturing environments without the need for a temperature-controlled inspection room.
Starrett Digital Comparator Streamlines Part Inspection
Source: The L.S. Starrett Co.
The L.S. Starrett Co.’s HDV250 digital comparator is engineered to provide improved surface illumination, clearer image quality and enhanced measurement accuracy for manufacturing environments. The HDV250 is said to modernize the optical comparator workflow by replacing the traditional projection screen with a high-resolution camera and digital monitor while maintaining precise, crosshair-based measurement methodology. The result is sharper visualization, more reliable surface feature identification and improved inspection consistency.
At the core of the HDV250 is an integrated LED ring light-based surface illumination designed to provide enhanced surface contrast and clearer edge definition across a wide range of part finishes, especially for features that cannot be backlit. The advanced lighting system improves image clarity, enabling operators to inspect with greater confidence and micron-level precision.
Hainbuch ID Clamping Mandrel Boosts Machining Stability
Source: Hainbuch
Hainbuch’s Maxxos family of mandrels features the Maxxos T-212, an ID clamping solution engineered around the concept that geometry creates rigidity. The Maxxos design features a hexagonal pyramid clamping interface that replaces the traditional round mandrel connection between the mandrel body and the segmented clamping bushing. Instead of relying on friction alone, the hexagonal geometry creates a positive mechanical fit that increases torque transmission and resistance to vibration.
The result is a mandrel that holds parts with stability, even during aggressive machining operations. This added stability enables shops to increase feed rates, take heavier cuts and maintain consistent part quality while extending tool life.
MaxValue
Cogsdill single pass deburring at the spindle!
CERATIZIT
Walter Surface Technologies
Automation
Metrology Matters
Don’t look at inspection equipment as a necessary evil. Embrace new industrial metrology technology as shown at IMTS 2026 to increase your manufacturing operation’s profitability.
Why Not Lights-Out Inspection?
Consider a process to enable your CMM to inspect multiple parts unattended, thereby minimizing the impact that part measurement has on your company’s bottom line.
CAD/CAM
Webinar Recap: Streamlining Swiss Machining Through Automation
See how CAMWorks 2026 cuts Swiss-style CNC programming time by 70%+ with automatic feature recognition, full machine simulation, and smart segmentation tools.
WEBINAR: From Machine Data to Guided Action: How Modern Shops Are Closing the Execution Gap
  In this webinar, MachineMetrics Product Manager Josh Fish is joined by Pindel Global Precision's Thomas Deslongchamps, for a candid look at what closing the execution gap actually looks like inside a precision machining shop.
CERATIZIT
