Designed on Earth. Proven in Orbit.
The Promise of Rotational 3D Printing
Students at ETH Zurich have developed a laser power bed fusion machine that follows a circular tool path to print round components, thereby being able to process multiple metals at once.
This finished, high-pressure turbine stator with a diameter of 75 mm is a good example of the types of aerospace and other parts that can be 3D printed via the Rapture machine’s rotating design. Source (all images): Michael Tucker/ETH Zurich
Virtually all modern rocket engines rely on 3D printing to maximize their performance with tight coupling between structure and function. Students at ETH Zurich have now built a high-speed, multi-material metal printer — a laser power bed fusion (LPBF) machine that rotates the powder deposition and gas flow nozzles while it prints — which means it can process several metals simultaneously and without process downtime. The machine could fundamentally change the 3D printing of metal parts, resulting in significant reductions in production time and cost.
The team of six bachelor’s students in their fifth and sixth semesters developed the new machine in the Advanced Manufacturing Lab under the guidance of ETH Professor Markus Bambach and Senior Scientist Michael Tucker as part of the Focus Project Rapture. In a mere nine months, the students realized, built and tested their idea. The machine is particularly aimed at applications in aerospace featuring approximately cylindrical geometries, such as rocket nozzles and turbomachinery, but is also of broad interest for mechanical engineering.
Project lead Tucker explains that the project came about from a very specific challenge: developing bi-liquid-fueled rocket nozzles for ARIS, the Swiss Academic Space Initiative, that is building its own rockets with visions of reaching into space. Within the next few years, ARIS aims to reach the Kármán Line, the internationally recognized boundary of space set at an altitude of 100 kilometers beyond which the atmosphere is too thin to support flight by aircraft without special propulsion.
To withstand the intense heat and pressure over an extended launch, rocket nozzles should ideally be made of multiple metals. For example, their interior can be made of heat-conducting copper with integrated cooling channels and their exterior of a heat-resistant nickel alloy. “For small players like our student rocket team, this sort of multi-material technology has up to now been too complex and too expensive, putting it out of reach,” Tucker says.
The new 3D printer enables two different materials to be simultaneously fused by a laser on the rotating platform.
The heart of the new machine is a rotating platform that enables a high-speed printing process. Unlike conventional rectilinear LPBF machines, where a new layer of powder is applied after each layer is melted, the Rapture machine works non-stop thanks to its rotating platform. This means that powder is applied and fused by the laser simultaneously, which significantly enhances productivity. This reduces the manufacturing time for cylindrical components by more than two thirds.
“This process is ideally suited to rocket nozzles, rotating engines and many other components in the aerospace industry,” Tucker explains. “They typically have a large diameter, but very thin walls.”
While the machine is also capable of producing non-axisymmetric or even arrays of parts, the rotating method is particularly effective for producing precisely this geometry.
Printing Two Metals Simultaneously
The rotating machine can process two different metals in a single operation. Conventional systems require several steps and a much greater quantity of metal powder. As separation and recovery of mixed powder remains an open challenge, today, much of this powder becomes waste. The new method only deposits the material where it is needed within the component, thereby reducing waste.
To the left is a conventional 3D printer. To the right is the rotating Rapture machine, in which the laser continually fuses the powder.
The machine features a mechanism that blows inert gas over the area where the powder is fused. This prevents the component from oxidizing while it is being printed. Soot, spatter and other by-products are systematically extracted via an outlet. “At first we underestimated the extent to which the gas flow mechanism affects product quality,” Tucker says. “Now we know it’s crucial.”
Thanks to the rotating architecture of the newly developed machine, the local gas flow conditions can be controlled much more tightly than with a conventional machine.
Customized, Not Standard Components
The students faced several technical challenges when developing the novel LPBF machine, one of which involved the synchronization of the scanning laser with the rotation of the gas inlet and powder supply. In addition, as many of the parts needed for the machine are not commercially available, the team designed its own. These include a rotatable connection for the gas inlet and a system that automatically refills the powder during operation.
Nonetheless, the team has managed to build a machine that almost looks ready for industrial application. For Tucker, this was one of the highlights of the Focus project. “The fact that a team of students developed and built a functioning machine in nine months is pretty remarkable,” he notes.
Potential for Aerospace, E-mobility and More
As well as concrete application for ARIS and for the aerospace industry in general, the team sees potential applications in other sectors, such as in aircraft and gas turbines, and for electric motors in which ring-shaped geometries are the norm. Owing to its novelty and tremendous commercial potential, a patent application was filed by ETH covering the rotary multi-material LPBF technology, which has since been nominated for the ETH Spark Award.
The components manufactured so far with the prototype have a diameter of up to 20 centimeters. The research team is now looking at scaling the process to higher speeds and larger diameters, and they are currently looking for industry partners to collaborate with them to further develop and deploy this revolutionary technology.
AS5202 or SAE J1926 Port Kits by SCT
CONTRAX 2027
Nakanishi EmaxEVOlution Micro Grinder
Precision Meets Productivity
Additive
Additive Manufacturing Adds to Vertically Integrated Knowledge at Penn United
The employee-owned manufacturer’s deep knowledge and experience in traditional manufacturing prepared it to adopt additive. Now, the investment is paying off.
Upgrading Bar Feeder Components with Metal 3D Printing
Index is exploring redesigning and optimizing parts for bar feeders inside its multi-spindle turning centers using a low-cost metal 3D printing platform from One Click Metal.
Craftsman Cribsheet No. 143: 3D Printing Technology for the Shop
Exploring the various 3D printing technologies and how they relate to work in our shops.
Additive
The Promise of Additive Manufacturing for Paul Horn GmbH
Additive manufacturing offers various benefits for cutting tool manufacturers such as reduced tool weight and the creation of complex internal coolant channels that cannot be produced via traditional CNC machining methods. Here is how it currently plays out at one such German company.
Swiss-Types
Webinar Recap: Streamlining Swiss Machining Through Automation
See how CAMWorks 2026 cuts Swiss-style CNC programming time by 70%+ with automatic feature recognition, full machine simulation, and smart segmentation tools.
WEBINAR: From Machine Data to Guided Action: How Modern Shops Are Closing the Execution Gap
  In this webinar, MachineMetrics Product Manager Josh Fish is joined by Pindel Global Precision's Thomas Deslongchamps, for a candid look at what closing the execution gap actually looks like inside a precision machining shop.
Airtech 3D printing Solutions
