End-Mill Milling Highlights Five-Axis Capability
Kern Precision IMTS booth visitors can submit worn tools for a demonstration of what is possible when linear motors combine with micro-gap hydrostatics.
Machining worn end mills on the show floor might seem like a promotion fit for a tool grinding company, but Kern Precision does not specialize in tool grinders. Rather, its focus is high-precision five-axis machines like the company’s Micro HD, which cuts materials that might otherwise be deemed ill-suited for machining – namely, sintered carbide and ceramics. To prove the point, the company invites visitors to bring in their own tools to use as “workpieces” for a contour-cutting demo.
Although this demonstration focuses on two relatively slim diameters – ¾” and 20-mm end mills – Kern’s ambitions for its new machine are anything but small. Linear motors and micro-gap hydrostatics (claimed to be a unique combination for a “true” five-axis machine), as well as fundamentals like thermal stability, dynamic acceleration and stick-slip-free motion, offer the possibility to replace other, more time-consuming processes.
One application where the Micro HD improves upon older, slower processes is the machining of punches for cutting inserts and medical tablets that were once produced via EDM. Another is cutting threads to an accuracy of less than 1 um in relatively brittle, 40%-silicon aluminum alloy for space telescope components.
Swiss Machining Demo Shows Off Carbide Cutting Tool Lines
Pilot Precision, Palbit’s exclusive U.S. distributor, showcases Palbit’s cutting tools as well as its own broaching and drilling products.
Emag VT 4-Axes Lathes for Shaft Production Maximum Performance
IMTS 2022: The lathes are said to provide short cycle times, high-precision machining and safe processing with the VT series of turning machines literally turning the classic horizontal machining process on its head.
Marubeni Citizen-Cincom Twin-Turret Lathes for Flexible Tooling
Miyano machines are designed to ensure high rigidity, high accuracy and long life.
